cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Script not executing properly
On a Juniper router, need to drop down into the shell to execute a command to get some extra low-level grep commands.
NCM doesnt seem to want to do anything with it and fails to execute the command.
Any ideas on what I am doing wrong, or how to help this along?
start shell
${Delay:2}
cli -c "show ethernet-switching table interface all|match xe-" | egrep -v database | awk '{print $2 " " $4}'
Email I get shows:
SolarWinds Network Configuration Manager
  Scheduled Job Notification
___________________________________________________________________________
  8/22/2019 5:21:23 PM : Started interface mac check for multiples
  Execute Command Script on Devices
  1 devices selected
  Devices: 1
  Errors: 0
  OCC2 (10.22.6.146):
  8/22/2019 5:22:25 PM : Completed interface mac check for multiples
  Execution time : 1 minute 1 second
Labels (1)
0 Kudos
Off the top of my head, when you change the shell does the prompt change?  You can modify device templates to recognize a different prompt like so
https://support.solarwinds.com/SuccessCenter/s/article/Adjust-modify-or-change-a-device-template-use...
- Marc Netterfield, Github
0 Kudos
when you log into in the shell it changes the prompt to % which is seen above.Using tht link you sent, I am not sure how to read the instructions on that.
Add below line (command) to the template:
<Command Name="VirtualEnablePrompt" Value="#"/>
So the value instead of # becomes a % and then execute my command?
so like this?
<Command Name="VirtualEnablePrompt" Value="%"/>
looks like i got an error back in the email.
  Missing name for redirect.
0 Kudos
