I've added one of our routers to Cirrus and it logs in fine but does not seem to login to enable, when I try and run a command I get the following
show IP Traffic
Pilgrim-Lincoln>show IP Traffic
Which shows it is connected but not logged into enable, our console password is the same as our enable password and it's all configured correctly in the node details, anyone know why it's not logging into enable.
Node Details
Node ID {635B8960-ED18-4694-BBF7-941292EEE7CE}
Node Name Pilgrim-Lincoln ${SysName}
Node Group
IP Address 10.42.1.5
SNMP Community String public ${GlobalCommunity}
Comments
Discovered Properties
Reverse DNS
Response Time 1 ms
Response Error OK
Device Status Up
SNMP Level SNMP V2
System Name Pilgrim-Lincoln
System Description Cisco Internetwork Operating System Software
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(24), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 28-Apr-04 15:30 by kellmill
System Contact
System Location
System OID 1.3.6.1.4.1.9.1.186
Vendor Cisco
Machine Type Cisco 2611
Last Boot 06:01 AM
OS Image C2600-I-M
OS Version 12.2(24), RELEASE SOFTWARE (fc1)
Supported Config Types Running, Startup
Next Rediscovery 09:52 AM
Next Poll 09:07 AM
Login Information
User Name
Password ********
Enable Level enable 15
Enable Password ********
Communication
Device Command Template Auto Determine
Command Exec Protocol TELNET ${GlobalExecProtocol}
Config Transfer Protocols TELNET ${GlobalTransferProtocol}
Last Login Result Login OK
Browse via HTTPs No
Last Inventory 08:55 AM
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
