cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
NCM roles to use Firmware Upgrade
Jump to solution
In our environment if the user is not administrator therefore cannot run the Firmware upgrades
My question is: If there's  anyone who has a work around for a non admin user but with full NCM Administrator role to run the Firmware Upgrades?
Thank You..
1 Solution
I ran into this same issue with NCM.  I ended up giving admin access to just 2 of my network engineers.  I am hoping that this can be corrected in an upcoming update to NCM. I hate giving admin access to my monitoring system for someone to use a module.  I think this is a result of the fact that in years past; the role of "Monitoring Engineer" wasn't really a thing.  But now, that is my role and I should be able to control who can do what within the system without having to just give blanket admin access to the console.
0 Kudos
0 Kudos
Thanks for quick response looks like that is all I can do for now.
You can go voice your thoughts on the Feature Request I posted within the NCM space as well if you would like.
https://thwack.solarwinds.com/t5/NCM-Feature-Requests/Remove-the-need-for-Admin-Access/idi-p/597139#...
0 Kudos
