cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
NCM reporting MisMatch between Startup and running configurations where there are NONE
Wonder if you can help me identify reason why I NCM is identifying mismatch between startup and running configuration but when I check the configurations there are none.
we are mainly a Brocade/Ruckus environment. Initially I had to add some comparsion exceptions but was working fine but this past week seeing mismatch reported for some nodes. I did verivy
any suggestions?
0 Kudos
