cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
NCM Script Management
We're currently in the process of implementing a new syslog server which means we have to go into all of our switches and change the logging host. I'm trying to create a script I can just execute instead of going into each and every switch.
I go to My Dashboards -> Network Configurations -> Configuration Management -> Script Management
I added a new script:
configure terminal
no logging host X.X.X.X
logging host X.X.X.X session-id string access-switch
end
write memory
I check on it in Transfer Status and see
config terminal
Command authorization failed.
% Invalid input detected at '^' marker.
end
write memory
I've tested it without the configure terminal command and checked the Execute Script in Config Mode to see if that would make a difference, same error. I tried only doing one line at a time, same error. I tested it with a simple show command and that works.
Anyone have any advice or experience working with the scripts?
Tags (2)
0 Kudos
Did you get it into enable mode in the script?
I find the compliance portion of NCM to be easier to do things like this overall.   Here is a link to a similar task, making sure invalid NTP servers aren't used by removing those and setting the correct ones.
https://thwack.solarwinds.com/t5/NCM-Discussions/Automated-Config-clean-up/m-p/312578#M15517
Thank you, I think I like this way better, this looks like it might run a lot smoother than my way.
0 Kudos
When you tested were you using the same account that ncm uses to access your devices?
- Marc Netterfield, Github
I did not think of that, thank you! I will give that a try.
0 Kudos
