cancel
Showing results for
Search instead for
Did you mean:
Create Post
NCM Compliance Check for Storm Control and advise if not correctly set
I would like to compliance report on  my interfaces for any that do not have Storm control Set as per our SOPs
storm-control broadcast level 10.00
storm-control multicast level 10.00
Anyone got any ideas or guides i can use.
In the below Example we should get a violated on eth 1/16.as has wrong settings.
interface Ethernet1/12
description Main Link
switchport mode trunk
switchport trunk allowed vlan 2-4
interface Ethernet1/16
description Backup link
storm-control broadcast level 5.00
storm-control multicast level 5.00
0 Kudos
1 Reply
Product Manager
Product Manager
This could be as simple as just defining a rule with Alert on the rule below if:  "String is NOT found"
Then place the string value to be:
You'd then place in a policy and then create a report or add the rule to an existing report etc.  It just depends on how you want to use this report.   If you want to look at a specific interface(s) you can use the advanced config block and more.
0 Kudos
