cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 7
Identify Nodes Using SNMP Credential Sets
Hello,
We have somehow created a large number of SNMPv3 Credential Sets as people are adding nodes. These credentials are standard so I am trying to set them to one set and remove the duplicates. However, when I look at the Credential Sets it just shows me a quantity of nodes using. I need to identify which nodes are using them so I can update them with the standard set. I did some research and found some nice reports that help find WMI credentials but not SNMPv3. I also found the support document that informs you to query the DB and then use the ID to find them. However, I'm not that knowledgeable of the DB since we aren't using a local DB but connect to a SQL server.
Is it possible to make a report with this information?
Thanks!
0 Kudos
