cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Level 7
How to script firmware upgrades to stacked switches?
I need to upgrade the firmware on some stacked Avaya 3626 & 3650 switches.
My understanding is that to script this I would need to use the switch IP, however as the switches are stacked they share the same IP.
So how do I get my script to differenentiate between the 2 to 5 switches in the stacks, especially when I have a mix of 3650's & 3626's?
Thanks in advance,
Ian
0 Kudos
