Hello all,
We are in the process of reviewing running configurations for STIG violations in the compliance section of NCM.
What I'm having an issue with is creating an operational Regex string that will check all access port configurations and exclude any trunks.
It looks like this can be accomplished with a well written Regex in the "Config block start" field however I'm a bit of a novice with Regex. (2 days in on learning this stuff)
I could have it start at "switchport mode access" however when an admin goes to check compliance it doesn't show the interface as the start line will be "switchport mode access"
Thank you
