Has anyone seen this error?
ERROR: Unable to get image filename "{IOS version}" from firmware upgrade storage
I thought that maybe the issue was that the files were locked. Sure enough, the files were not unblocked. I unblocked them, and ran the upgrade process again. Same error. I looked it up on the Customer Portal, and found this in the Success Center. Success Center
It states:
NCM users sometimes get the following error when using the Firmware upgrade feature: ERROR: Unable to get Image filename "xxx" from firmware upgrade storage
NCM 7.2 - EOL;NCM 7.3 - EOL;NCM 7.4 - EOL;NCM 7.5 - EOL;NCM 7.6;NCM 7.7;NCM Evaluation;NCM 7.8
Fair enough, so I go look at the files and directory, and don't see any restrictions. So, I log into the switch, and run the command I copied from the Firmware Upgrade script, "copy t10.6.2.13/c2960x-universalk9-mz.152-6.E2.bin flash:/"
The command works perfectly; it downloads the file from the tftp server without issue. So the problem does not seem to be an inability to access the file.
Any suggestions anyone?
