Hi there,
I have a Blue Coat ProxySG 900 device which I was hoping to automatically backup via NCM. The config backs up OK, but I get the following error message within NCM.
"Transfer failure due to timeout waiting for success or failure prompt"
When running a session trace, I also get the following message,
[4/06/2013 4:49:35 PM] Config file not found in TFTP Root: D:\Program Files\SolarWinds\Orion\NCM\Config-Archive\84560.config - Retry. RetryCount: 1
The config attempts to backup twice more, but can't because the 'actual' filename it is using already exists. The filename that is being backed up is.... 'D:\Program Files\SolarWinds\Orion\NCM\Config-Archive\SBISG900a'
Where does the '84560.config' filename come from?
I am using the NCM template below;
<!--Copyright 2007 SolarWinds.Net All rights reserved-->
<Configuration-Management Device="Blue Coat Proxy SG900" SystemOID=" 1.3.6.1.4.1.3417.1.1.34"><Commands>
<Command Name="RESET" Value="${EnterConfigMode}${CRLF}line-vty${CRLF}length 0${CRLF}exit${CRLF}${ExitConfigMode}"/>
<Command Name="EnterConfigMode" Value="configure terminal${CRLF}"/>
<Command Name="ExitConfigMode" Value="exit${CRLF}"/>
<Command Name="Startup" Value="configuration"/>
<Command Name="Running" Value="configuration"/>
<Command Name="DownloadConfig" Value="show ${ConfigType}"/>
<Command Name="UploadConfig" Value="${EnterConfigMode}${CRLF}${ConfigText}${CRLF}${ExitConfigMode}"/>
<Command Name="DownloadConfigIndirect" Value="upload configuration"/>
<Command Name="Version" Value="show version"/>
</Commands>
</Configuration-Management>
All of my Cisco equipment is backing up fine, placing them in 'hostname' folders then 'date' folders. This is the only device I am having issues with. Any help would be greatly apprecaited!!!!!
Regards,
Brett
Hi Brett,
Did you ever have success in getting your SG900 (blue coat) devices backed up in NCM ?
We have same appliances and would be interested if you made progress. Likewise if we have success we will publish info.
Ellen.
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
