cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 15
A solution to multi-context config download with NCM (Cisco ASA, FWSM...)
NCM 7.x has several node management improvements (common with Orion Core/NPM, new Discovery Sonar…).
Due to these changes, NCM 7.x has stricter rules related to node uniqueness and duplicate nodes are not allowed anymore in NCM 7.0 (because NCM nodes are being handled by Orion Core, which does not support duplicate nodes).
This NCM 6.x capability was sometimes used to deal with devices such as the Cisco ASA, which require management of multiple contexts.
The solution in NCM 7.x (can work in NCM 6.1 as well) uses multiple Config Types:
Solution:
1.       In Win32 NCM application, add a new Config Type for each context (for example Context1, Context2).
2.       Specify in your device template, how to switch to each context (see example below).
3.       Include the ${ConfigType} macro in the Reset Command.
4.       Make sure to specify the RegEx value in the Reset command. Depending on your prompt settings, the value should be '#', '>', ']', etc.
5.       Avoid using ${ConfigType} macro in the DownloadConfig command. Make sure the command is the right one, e.g. "show running-config".
Device Template Example:
<Command Name="RESET" Value="${ConfigType}" RegEx="#" />
<Command Name="Context1" Value="command to switch to Context1"  />
<Command Name="Context2" Value="command to switch to Context2 "/>
<Command Name="DownloadConfig" Value="show running-config"/>
Explanation:
When NCM downloads a configuration, the first command issued is the ‘Reset’ command defined in the device template.
The ${ConfigType} macros will be replaced by the appropriate switch context command, based on the config type selected for the dowload.
The context will be dynamically switched before the download command is executed.
When the context is changed, so is the prompt. In order to recognize the prompt, a regular expression (RegEx) must be used to ignore the variable part of the prompt.
Example:
Let’s assume the command mode prompt after login is : Tex-3750#
-          After switching to Context1, the command mode prompt becomes Tex-3750-Context1#.
-          After switching to Context2, the command mode prompt becomes Tex-3750-Context2#.
The RegEx to use in the reset command should match the common portion of the prompt in both contexts. In this example this could be RegEx="#".
An NCM user shared the result of his work (FWSM on NCM 6.1):
Should work the same in NCM 7.0. Thanks
Message was edited by: Jiri Cvachovec
Labels (1)
Level 7
Howdy folks,
Please forgive my ignorance right off the bat, but I've inherited an NCM 7.3 server have muddled my way through some of the simple things, have hit the proverbial brick wall concerning ASA backups. I have two Firepower 9300s, each with an ASA security module. the ASA modules are run clustered, which really has bearing on the backup, but have 18 contexts that I need to backup. These 18 contexts are configured as transparent firewalls use Bridged Virtual Interfacesm so I can't just build a node object in NCM and back it up. so much for the background... I would like to know if someone could help an old cowboy out with a step-by-step, paint-by-numbers, coloring book version of how to build a the backup templates, where they're stored and how to integrate them into a back job that can copy the System context and download the ".cfg" files of the other contexts. .
I thank you all in advanced
R/S
Cody (just and old cowboy what somehow got stuck in IT)
0 Kudos
Level 9
But the only problem that I see with the suggestions that have been given is that there isn't a resolution for the startup and running config for each context. I'm sure everyone understands the use of the ASA security context. But just like any other single context cisco device, you can make changes and not perform a "write memory". This will result in config differences between startup and running. The same goes for each context. Issuing the command "more disk0:/context1.cfg" only gives you the startup for that context. And changing into the different contexts and performing "show run" only gives you the running config. I am testing the creation of additional config types as such: context1-startup; context1-running. But this doubles all the working needed in order to get configs.
0 Kudos
Level 7
i was after this for a week almost now in our infrastructure which has an ASA Cisco 5585 with 4 Contexts...after following all these posts and tweaking around I finally managed to understand a bit on the {ConfigType} directive of NCM and managed to successfully create a single job to backup all 4 contexts in our primary/secondary ASA...Thank you all for your valuable posts/hints...
0 Kudos
Level 9
I copied deee-b@lue's script to show what worked for me;
<!-- edited with XML Spy v4.4 U (http://www.xmlspy.com) by () -->
<!--Copyright 2005 SolarWinds.Net All rights reserved-->
<Configuration-Management Device="Cisco PIX" SystemOID=" 1.3.6.1.4.1.9.1.451">
<Commands>
  <Command Name="RESET" Value="terminal width 0${CRLF}terminal length 0${CRLF}${ConfigType}" RegEx="p06cd01-ghe-int-fw-01" />
                <Command Name="system" Value="changeto context system"  />
                <Command Name="mgmt" Value="changeto context mgmt"  />
                <Command Name="Production" Value="changeto context Production"  />
                <Command Name="Preprod" Value="changeto context Preprod"  />
                <Command Name="Cert" Value="changeto context Cert"  />
                <Command Name="Perf" Value="changeto context Perf"  />
                <Command Name="Admin" Value="changeto context Admin"  />
  <Command Name="Reboot" Value="reload noconfirm"/>
  <Command Name="EnterConfigMode" Value="config terminal"/>
  <Command Name="ExitConfigMode" Value="quit"/>
  <Command Name="Startup" Value="startup"/>
  <Command Name="Running" Value="running"/>
  <Command Name="UploadConfig" Value="${EnterConfigMode}${CRLF}${ConfigText}${CRLF}${ExitConfigMode}"/>
  <Command Name="DownloadConfigIndirect" Value="write net ${StorageAddress}:/${StorageFilename}"/>
  <Command Name="UploadConfigIndirect"/>
  <Command Name="EraseConfig" Value="write erase${CRLF}Yes"/>
  <Command Name="SaveConfig" Value="write memory"/>
  <Command Name="Version" Value="show version"/>
</Commands>
</Configuration-Management>
As you can see, I changed the Command Names to match the context names. Set the Device Template to this template on the Node in the NCM section. Then in NCM Settings > Config Settings, I would add Config Types of system, mgmt, Production, Preprod, Cert, Perf, and Admin. Then in a new configuration backup job (to keep from interfering with the backups of older firewalls), I would select those configuration types in "Download Config Job" for the contexts I want to back up from those multiple context firewalls. It works great for me
0 Kudos
Level 9
thanks mkomera i used your post to backup all my firewall contexts.  one recommendation I have is replace the RESET line with this:  its generic for anyone that has a # in their prompt (everyone!):
<Configuration-Management Device="Cisco ASA" SystemOID="1.3.6.1.4.1.9.1.669">
<Commands>
  <Command Name="RESET" Value="terminal pager 0${CRLF}${ConfigType}" RegEx="#" />
  <Command Name="admin" Value="changeto context admin"  />
  <Command Name="cloud-infra" Value="changeto context cloud-infra"  />
  <Command Name="infra" Value="changeto context infra"  />
  <Command Name="tenant" Value="changeto context tenant"  />
</Commands>
I also changed the OID for my ASA 5525-X model, not sure how much this matters.
To find the menu to add the new contexts go below, took me awhile to find where its burried.
Lastly to find the actual device templates
ALL SETTINGS -> NODE & GROUP MANAGEMENT ->
0 Kudos
Level 7
Using many of these suggestions break the manual download of a startup-config (as running-config is hardcoded)
eg. pushing "download startup" actually downloads a running config.
I had success using this code to be able to download both the startup, running and system-context from an ASA:
(remember to have this code for both OID's old ASA hardware and new -X hardware.
<!--Multi Context Download tool for Meridian ASA 55xX Firewalls-->
<!--Apply this to the Admin Context only.  Do not download direct from other contexts as they are SNMP only-->
<Configuration-Management Device="Cisco ASA" SystemOID=" 1.3.6.1.4.1.9.1.773">
        <Commands>
<Command Name="Reset" Value="terminal pager 0${CRLF} ${ConfigType}" RegEx="#"/>
<Command Name="Context-1" Value="changeto context Context-1"/>
<Command Name="Context-2" Value="changeto context Context-2"/>
<Command Name="Context-3" Value="changeto context Context-3"/>
<Command Name="Context-system" Value="Startup-config{CRLF}changeto context system"/>
<Command Name="DownloadConfig" Value="Show ${ConfigType}"/>
          </Commands>
As shown in Red, the ${ConfigType} is used to be able to download both the running and startup config
The Green Startup-config{CRLF}
is what makes the magic, and enable download of startup config of the system context
0 Kudos
Level 7
Do I need to add these entrys as seperate config types?
0 Kudos
Level 7
Hi All,
Thank you for sharing every thing to date.  I have tried both methods and I still only download a single "system" configuration.  I've shown the two scripts below and would appreciate any feedback.  I must admit I don't know much about scripting so I've copied and pasted what I think should be the right text after reading through this solution.
Script 1
<Commands>
                <Command Name="Context1" Value="changeto context system"  />
                <Command Name="Context2" Value="changeto context mgmt"  />
                <Command Name="Context3" Value="changeto context Production"  />
                <Command Name="Context4" Value="changeto context Preprod"  />
                <Command Name="Context5" Value="changeto context Cert"  />
                <Command Name="Context6" Value="changeto context Perf"  />
                <Command Name="Context7" Value="changeto context Admin"  />
</Commands>
Script 2
<Configuration-Management Device="Cisco ASA Multi Context" SystemOID=" 1.3.6.1.4.1.9.1.669">
<Commands>
                <Command Name="System" Value="more system:running-config"/>
                <Command Name="Context1" Value="more disk0:/admin.cfg"/>
                <Command Name="Context2" Value="more disk0:/mgmt.cfg"/>
                <Command Name="Context3" Value="more disk0:/production.cfg"/>
                <Command Name="Context4" Value="more disk0:/preprod.cfg"/>
                <Command Name="Context5" Value="more disk0:/cert.cfg"/>
                <Command Name="Context6" Value="more disk0:/perf.cfg"/>
                <Command Name="MenuBased" Value="false"/>
  <Command Name="RESET" Value="terminal pager 0${CRLF}changeto context system${CRLF}" RegEx="p06cd01-ghe-int-fw-01"/>
                 <Command Name="Startup" Value="show startup"/>
                 <Command Name="Running" Value="show running"/>
                 <Command Name="DownloadConfig" Value="${ConfigType}"/>
                 <Command Name="SaveConfig" Value="write memory all${CRLF}Yes"/>
</Commands>
0 Kudos
Level 18
Just to make sure -- have you created custom config types for all the contexts?
Jiri
0 Kudos
Just adding my 2c.
Using Multiple Context ASA, but I wanted to get the equivalent on "more system:xxxx".
The more commands is ONLY supported in the system context, so obviously changing to each individual context and running the command doesnt work.
Below is the solution I found that works for me...
It's not perfect, as it only really pulls the startup configs that are saved to the flash but it allows us to backup the system context and all respective passwords etc.
Thought I would share as I'm sure others would have a similar issue.
Regards,
Marcus
<!--Copyright 2007 SolarWinds.Net All rights reserved-->
<!--Custom Collections for Multiple Context ASA and Specialist Configurations-->
  <Commands>
  <Command Name="Context-1" Value="more disk0:/context1.cfg"/>
  <Command Name="Context-2" Value="more disk0:/context2.cfg"/>
  <Command Name="Context-X" Value="more disk0:/contextX.cfg"/>
  <Command Name="RESET" Value="terminal pager 0${CRLF}changeto context system${CRLF}" RegEx="#"/>
  </Commands>
Level 12
My understanding of the idea of creating a new config type is so that NCM knows where to store the downloaded config in its repository. Am I correct in saying this? eg if it has downloaded a config from "con1" when it trys to store it in config repository it'll see that there are only 2 (default) types of config (containers?) to store it in: Running or Startup.
Also regarding the Device Template itself I have a question about how it actually works. How does NCM know in what order to execute the commands? I can see from the structure of the template it provides an instruction set however if it was to work its way down the instruction set sequentially it wouldn't make sense.
Hence I have arrived at the conclusion that there is an intelligence built into the generic download config job you can schedule in NCM that knows what commands to run and in what order but a modified or custom device template will provide NCM with the native commands it is not aware of.
How does NCM know how many contexts there is in a multi context firewall? My guess is that NCM just goes by the amount you declare in the bespoke template? If you delcare 3 contexts and name them accordingly NCM will attempt to change to each context variable that has been declared eg if your template includes
<Command Name="Context3" Value="command to switch to Context3 "/>
it will try to find each of these contexts and download each. Am I correct in saying this? Any help is greatly appreciated. TIA!
0 Kudos
Level 18
Hi Wayne Barry,
Your hypotheses are mostly correct. Let me add some details.
NCM handles the storage of downloaded configs automatically. You don't have to worry about that. Create a new config type, download the config and you'll see the exact structure yourself.
You should look at the device template not as a script but rather a repository of commands. NCM business logic needs different commands at different stages and the device template tells it what the command for a particular device looks like.
That's why the order of the commands generally doesn't matter; there are some exeptions though. (E.g. the order of Pre-commands does matter.)
You have to enter all the contexts/config types manually in the template; your assumption is correct. A natural feature request is to download (if not discover) all the contexts at once.
Regards,
Jiri
Level 12
Francois,
I was actually using following for RESET command, but not entirely sure to what extend it helped
<Command Name="RESET" Value="terminal width 0${CRLF}terminal length 0${CRLF}${ConfigType}"/>
0 Kudos
Level 18
You have to use the command for switching the context for your particular device. If the device command (like for ASA) is
changeto context mycontext1
then the Reset command should read
<Command Name="RESET" Value="terminal width 0${CRLF}changeto context ${ConfigType}"/>
and you have to create new config type "mycontext1".
Regards,
Jiri
0 Kudos
Level 12
Unless you follow with Francois suggestion of replacing ConfigType with whole context change command, like:
<Command Name="Context1" Value="changeto Context1"  />
Its really up to user at that point I suppose
0 Kudos
Level 18
Sorry, I don't really understand your comment. You have to define new config types that correspond with the contexts and then the Reset command as outlined above.
Jiri
0 Kudos
Level 12
Yes of course but as Francois suggested you can actually use whole command as a value instead of just context's name. So in fact you have 2 options
<Command Name="RESET" Value="terminal width 0${CRLF}terminal length 0${CRLF}${ConfigType}" RegEx="#" />
or
<Command Name="RESET" Value="terminal width 0${CRLF}terminal length 0${CRLF}changeto ${ConfigType}" RegEx="#" />
<Command Name="Context1" Value="Context1"  />
final result should be the same
0 Kudos
