cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 11
Seeking sql to retrieve Monitors assigned to Nodes
Seeking sql to retrieve Monitors assigned to Nodes - need to create an inventory report, any help would be great ?
0 Kudos
1 Reply
Level 14
Try this query
select
APM_AlertsAndReportsData.NodeId, APM_AlertsAndReportsData.ApplicationID, APM_AlertsAndReportsData.ComponentID,
Nodes.OwnerGroup, nodes.statusled, APM_AlertsAndReportsData.NodeName,
APM_AlertsAndReportsData.ApplicationStatus, APM_AlertsAndReportsData.ApplicationName,
APM_AlertsAndReportsData.ComponentStatus, APM_AlertsAndReportsData.ComponentName, APM_AlertsAndReportsData.DisplayType
from APM_AlertsAndReportsData
join Nodes on APM_AlertsAndReportsData.NodeId = Nodes.NodeID
order by Nodes.OwnerGroup, APM_AlertsAndReportsData.ApplicationName, APM_AlertsAndReportsData.ComponentName
I can't take the credit for it though.  This is the handiwork of Leon Adato from when he worked here.
