cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
SRM & VmWare EsXi 5.5 with Agent - There is a problem collecting asset data!
We have an error in the SRM Monitor.
Status: There is a problem collecting asset data!
We have Rently update from ESX 5.1 to ESX 5.5
Not for sure now if this issue was before the upgrade.
Because the collecting data is from last year 🙂
Anyway The URL is no longer exist  if I try to connect it: https://OP-Address/sdk/
Try to change gives the following pop-up:
The agent version:
So first I will fix this sdk issue.
Any suggestions?
0 Kudos
