cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 15
Resources for SolarWinds Lab - Orion Performance Tuning in a Virtualized Environment
Tips for configuring Microsoft SQL Server in a Virtual Machine (1002951)
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=100295...
Your Guide to Virtualizing SQL on vSphere (Part 1) - Storage provisioning and VM disk alignment
http://blogs.vmware.com/apps/2012/03/your-guide-to-virtualizing-sql-on-vsphere-part-1.html
CPU Overcommitment and Its Impact on SQL Server Performance on VMware
http://www.sqlservercentral.com/blogs/technobabble-by-klee-from-kleegeek/2012/12/17/cpu-overcommitme...
Top 10 Keys to Deploying SQL Server on VMware
http://www.brentozar.com/archive/2011/05/keys-deploying-sql-server-on-vmware/
Managing Orion Performance - SolarWinds
http://www.solarwinds.com/documentation/Orion/docs/Orionperformance.pdf
Deploying and Optimizing SQL Server for Virtual Machines
http://www.solarwinds.com/resources/whitepaper/deploying-and-optimizing-sql-server-for-virtual-machi...
Updated (Jun 2013) "Orion" Template for SAM (Note also that this updated template ships with SAM 6.0, so if you've already upgraded, or are planning the upgrade, the template will come with.)
http://thwack.solarwinds.com/docs/DOC-170557
