cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Northbound API for NPM, NCM and Traffic Analyzer
Do we have any built in APIs in NPM, NCM, Traffic analyzer which could be used for integrating the tool with other tools/UIs?
Use case:
we are looking for a Northbound API for NPM, NCM and NTA to integrate with Higher level NMS such as HP ov  or NetCool or NetAssure.
To cater to this need is there a standard northbound interface? If not what are the suggested method to interface with higher level NMS.
Anandan
0 Kudos
1 Reply
Level 17
You can download the Orion Software Development Kit v1.7. The SDK supports development in a number of different languages.
Also, of note, on November 13th, we'll be presenting a SolarWinds Lab episode specifically about the SDK, with some practical examples of how it can be used.
For more information and to sign up to get a reminder about SolarWinds Lab episodes, visit us at http://lab.solarwinds.com.
Last month, we did a joint presentation with Plexxi during thwackCamp. Check out that video.
And in December, Plexxi is doing a Demo Friday with SDNCentral to demonstrate how Plexxi's SDN solutions integrate with SolarWinds.
You can get more information and register for that webcast here.
0 Kudos
