cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
How to use WMI credentials stored in Orion with Powershell?
Hello everyone,
I'm currently working on a Powershell script that sends a "lodctr" command to several servers in my network (in this case, Windows 2003 Servers). The problem here is that to use an Invoke-Command inside Powershell, I need to input the credentials for each server individually and I'm working with a lot of servers. How can I use the WMI credentials that are already stored inside Solarwinds? The script I was working on is the following:
Add-PSSnapin SwisSnapin
$now = Get-Date
$later =$now.AddYears(99)
$creds = Get-Credential
$swis = Connect-Swis -Credential $creds -Hostname 10.161.236.25
$a = Get-SwisData $swis "SELECT NodeID FROM Orion.Nodes where Nodes.Description = @nodeDescription" @{nodeDescription = "Windows 2003 Server"}
Write-Host $a
foreach ($i in $a)
    # Unmanage
    Invoke-SwisVerb $swis Orion.APM.Application Unmanage @("N: $i", $now, $later, "false")
    # Lodctr /R
    Invoke-Command -ComputerName ${Node.Caption} -Credential ${CREDENTIAL} -ScriptBlock{lodctr /R:""}
    # Remanage
    Invoke-SwisVerb $swis Orion.APM.Application Remanage @("N: $i", $now, $later, "false")
Thanks!
Tags (3)
0 Kudos
1 Reply
Level 14
Inside of the template you need to edit the component.  If you want to use the credential applied to the node you would set the following:
Inside of your script you are already calling the credential correctly using the -credential ${CREDENTIAL} string.
Let me know if this works!
