cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
Change the default polling engine.
Hi All,
I need to change the default polling engine (Additional poller instead of primary poller) while adding a new node in solarwinds web console.
Kindly help me to do the same.
Thanks and regards,
Arunprasad.
0 Kudos
Level 12
I think he's specifically taking about the "Polling Engine" drop down in the "Add Node" page.  So that when users are adding nodes they get a defaulted to the right place.  Users don't know or care which polling engine they add nodes to, they just want them monitored.  I have to go back later and re-balance the polling engines and that can be difficult with ACL's and firewall rules.
Level 13
HI,
you can do this from manage node:
