cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
is Solairwinds can monitor Grass Valley products (broadcast TV equipment )
is Solarwinds can monitor Grass Valley products (broadcast TV equipment )
like Routers , XVP cards , Marinda items
regards,
0 Kudos
Level 8
Perhaps Grass Valley is not natively supported, but I took a look at Grass Valley's own GV Guardian monitoring product to how it would handle same tasks, and according to specs GV-G uses SNMP, RMON, WMI and Syslog to monitor broadcast gear.
...Orion NPM+LA could definitely handle most of that on its own.  SNMP MIBs for GV gear might be tricky.
Perhaps someone who knows for sure may chime in next...
Or it might be good to just install a local NPM+LA demo and see it for yourself to be certain.
Byron
Tags (1)
like @byronfelts mentioned, as long as there is an interface that we can query, there is a possibility to monitor.
Apart from SNMP I would also have a look into SAMs API Poller, when your devices have a REST API that you can query.
Kind regards,
Holger
0 Kudos
