cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
SolarWind integration with Power Bi
I would like to integrate the SolarWind dashboard in the organisation Power bi.
is there any API available for the same.
Tarun
0 Kudos
1 Reply
Hi Tarun,
You have two options; Use of the Orion REST API or direct to SQL database, with the benefits of going via the API being adherence to Account Limitation permissions and abstraction from DB schema changes. Benefits of going direct to database, primarily lie in performance.
Orion API information can be found on the github page here with knowledge on SWQL required for the API usage, as this is the syntax structure used by the API.
It would be useful for others if you post your results
0 Kudos
