I'm curious what the recommended max number of "Log Entries" are in one Log Analyzer Rule? How many strings are too many?
I have a rule with about 75 different strings in them, and the website freezes when trying to load it, but eventually will load everything. I also have a support case open for this but after 2 days, no one has touched it yet. One rule i need to create has about 399 entries to look for, and in creating one that needed approx 200, i broke it out in chunks of 50 when 70+ seemed unmanageable.
Lots of different situations. These are not 400 traps for just one or two issues, but just about anything that vendor's device could spit out that we want our engineers to acknowledge and take a look at. Between the 20-something vendors i have, there's just about 2,000 strings i need to look for and have in rules. Some of these are better suited for Orion's methods of alerting (for example, not relying on SNMP Traps for hardware health issues when Orion can do that) but for now i'm more worried about making rules that are too "large".
You might have better luck going the opposite route and creating rules to drop any events types that are not actionable, that way instead of sifting through a million events looking for useful data you only keep useful events in the db and immediately route everything else to the garbage? Log Manager is not exactly dialed in to operating as a full on a SIEM. It might be a 6 of one, half a dozen of the other kind of situation though.
I know in most sql queries having a long list of OR conditions against strings tends to be really hard on system performance, and you've already run into the limitations of the GUI itself to display the rules. I know in the regular alert builder I had some cases before where I used code to build alert conditions that had like dozens of lines of logic in them and they also were really slow to display as well.
