cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Need help setting up Kiwi Syslog Server
Hello everyone!
First post is, of course, a request for help!
I want to monitor my U-Verse router more closely. Unfortunately, even though the router is generating a syslog, my windows cannot see them.
My kiwi input is set up as follows:
The router address is 192.168.1.254 and the computer running kiwi is in a different subnet, 192.168.5.40. The wifi router between both computers is forwarding port 514.
I'm not sure what else to do. The 192.168.5.40 computer connects to the internet and to the router easily, so I don't think it is a routing issue...
Any guidance would be appreciated.
Diego
1 Reply
Level 7
Syslog uses UDP, so make sure that UDP is also selected in the Input options.
