As a system Engineer, I'm wanting to record the logs from a Cisco 877 router (troubleshooting) that is connected to my workstation via a USB-Serial connection and the rollover cable. Can this be done? Or should I configure one of the ethernet ports of the router to match our internal network? We prefer the 1st method if possible.
In general we do not want clients routers or their gear on our network, also if something should go bump in the process the ethernet ports will shutdown. the problem with the router is that it shuts off sporadically after about 5-15 minutes of uptime. Would like to see the las bit of information in the logs.
