cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
using bash commands in Device.CLI.Send Commands fails
Hi
I am trying to create a script in order to backup a F5 BigIP.
The scripts runs without issues on the device when i run it on the console(ssh) , but when i use Kiwi Cattools, the script fails.
The reason i''m using variables, is to be able to backup multiple F5 devices into one dir, retaining the ID of the device.
I must be doing something dumb, or i don't get it.
#!/bin/bash
terminal width 120
FTPHOST=[IP]
HOST=$HOSTNAME
USER=F5
PASS=XXXXX
UPATH1=Config'/'Current'/'
UPATH=`date +%Y'/'%m'/'%d`
FPATH="$UPATH1$UPATH"
cd /config
tmsh -c "save sys config base"
cp bigip_base.conf $HOST.conf
ftp -inv << EOF
open $FTPHOST
user $USER $PASS
bin
mkdir $FPATH
put /config/$HOST.conf /$FPATH/$HOST.txt
close
bye
EOF
KiwiCattools fails on reading the variables, i get "waiting for respons to command", waiting for an echo.
I am using Device.CLI.Send Commands.
Question ofcourse is... :how to fix it, how to set specifics for each device using variables ? Am i missing the point completly? Is it even possible what i''d like to achieve.
What am i doing wrong?
If anybody can point me to some docs on how to use bash within scripts for KiwiCatTools, that would be great too.
Thank you in advance.
With kind regards, Thijn
Labels (1)
0 Kudos
Level 15
Please post Putty log information showing these commands being run.
0 Kudos
Ofcourse... the logs, i should've included this into the original post.
I have two logfiles.. one is the output of KiwiCattools., the other is the output as seen in a SSH session.
Kiwicattools log
2014-12-11 10:35:51 3-Info 0 Kiwi CatTools Service Performing activity - Run Now
2014-12-11 10:35:52 3-Info 0 Kiwi CatTools Service Loading activity: Backup F5. Schd: 36
2014-12-11 10:35:52 4-Debug 0 Kiwi CatTools Service Marshaller - Running script. Device: hostname.log
2014-12-11 10:35:53 4-Debug 1 hostname.log.SSH Fingerprint: 8b:7c:0a:21:9d:3d:6d:6b:5f:db:6a:1c:10:a8:88:8d
2014-12-11 10:35:53 4-Debug 1 hostname.log.Connected to 10.0.0.1
2014-12-11 10:35:53 4-Debug 1 hostname.log.Login F5 Big IP: hostname.loc
2014-12-11 10:35:53 4-Debug 1 hostname.log.Waiting for command prompt
2014-12-11 10:35:53 4-Debug 1 hostname.log.DeviceHostnameID: [USER@hostname.loc:Standby:In Sync] ~
2014-12-11 10:35:53 4-Debug 1 hostname.log.Login to hostname.log.was successful
2014-12-11 10:35:54 4-Debug 1 hostname.log.Waiting for an echo of #!/bin/bash command
2014-12-11 10:35:54 4-Debug 1 hostname.log.Waiting for a response to: #!/bin/bash
2014-12-11 10:35:54 4-Debug 1 hostname.log.Waiting for an echo of FTPHOST=IPADDRESS command
2014-12-11 10:35:54 4-Debug 1 hostname.log.Waiting for a response to: FTPHOST=IPADDRESS
2014-12-11 10:35:54 4-Debug 1 hostname.log.Waiting for an echo of HOST=$HOSTNAME command
2014-12-11 10:35:54 4-Debug 1 hostname.log.Waiting for a response to: HOST=$HOSTNAME
2014-12-11 10:35:54 4-Debug 1 hostname.log.Waiting for an echo of USER=F5 command
2014-12-11 10:35:55 4-Debug 1 hostname.log.Waiting for a response to: USER=F5
2014-12-11 10:36:25 2-Warning 1 hostname.log.Did not receive expected response to command: USER=F5
2014-12-11 10:36:25 4-Debug 1 hostname.log.Waiting for an echo of PASS=PASS command
2014-12-11 10:36:25 4-Debug 1 hostname.log.Waiting for a response to: PASS=PASS
2014-12-11 10:36:55 2-Warning 1 hostname.log.Did not receive expected response to command: PASS=PASS
2014-12-11 10:36:55 4-Debug 1 hostname.log.Waiting for an echo of UPATH1=Config'/'Current'/' command
2014-12-11 10:36:55 4-Debug 1 hostname.log.Waiting for a response to: UPATH1=Config'/'Current'/'
2014-12-11 10:37:25 2-Warning 1 hostname.log.Did not receive expected response to command: UPATH1=Config'/'Current'/'
2014-12-11 10:37:25 4-Debug 1 hostname.log.Waiting for an echo of UPATH=`date +%Y'/'%m'/'%d` command
2014-12-11 10:37:25 4-Debug 1 hostname.log.Waiting for a response to: UPATH=`date +%Y'/'%m'/'%d`
2014-12-11 10:37:55 2-Warning 1 hostname.log.Did not receive expected response to command: UPATH=`date +%Y'/'%m'/'%d`
2014-12-11 10:37:55 4-Debug 1 hostname.log.Waiting for an echo of FPATH="$UPATH1$UPATH" command
2014-12-11 10:37:55 4-Debug 1 hostname.log.Waiting for a response to: FPATH="$UPATH1$UPATH"
2014-12-11 10:38:26 2-Warning 1 hostname.log.Did not receive expected response to command: FPATH="$UPATH1$UPATH"
2014-12-11 10:38:26 4-Debug 1 hostname.log.Waiting for an echo of echo $FPATH command
2014-12-11 10:38:26 4-Debug 1 hostname.log.Waiting for a response to: echo $FPATH
2014-12-11 10:38:56 2-Warning 1 hostname.log.Did not receive expected response to command: echo $FPATH
2014-12-11 10:38:56 4-Debug 1 hostname.log.Waiting for a response to:
2014-12-11 10:39:26 2-Warning 1 hostname.log.Did not receive expected response to command:
2014-12-11 10:39:26 4-Debug 1 hostname.log.Waiting for a response to:
2014-12-11 10:39:56 2-Warning 1 hostname.log.Did not receive expected response to command:
2014-12-11 10:39:56 4-Debug 1 hostname.log.Waiting for an echo of cd /config command
2014-12-11 10:39:56 4-Debug 1 hostname.log.Waiting for a response to: cd /config
2014-12-11 10:40:26 2-Warning 1 hostname.log.Did not receive expected response to command: cd /config
2014-12-11 10:40:26 4-Debug 1 hostname.log.Waiting for an echo of tmsh -c "save sys config base" command
2014-12-11 10:40:26 4-Debug 1 hostname.log.Waiting for a response to: tmsh -c "save sys config base"
2014-12-11 10:40:58 2-Warning 1 hostname.log.Did not receive expected response to command: tmsh -c "save sys config base"
2014-12-11 10:40:58 4-Debug 1 hostname.log.Waiting for an echo of cp bigip_base.conf $HOST.conf command
2014-12-11 10:40:58 4-Debug 1 hostname.log.Waiting for a response to: cp bigip_base.conf $HOST.conf
2014-12-11 10:41:28 2-Warning 1 hostname.log.Did not receive expected response to command: cp bigip_base.conf $HOST.conf
2014-12-11 10:41:28 4-Debug 1 hostname.log.Waiting for an echo of ftp -inv << EOF command
2014-12-11 10:41:28 4-Debug 1 hostname.log.Waiting for a response to: ftp -inv << EOF
2014-12-11 10:41:58 2-Warning 1 hostname.log.Did not receive expected response to command: ftp -inv << EOF
2014-12-11 10:41:58 4-Debug 1 hostname.log.Waiting for an echo of open $FTPHOST command
2014-12-11 10:41:58 4-Debug 1 hostname.log.Waiting for a response to: open $FTPHOST
2014-12-11 10:42:28 2-Warning 1 hostname.log.Did not receive expected response to command: open $FTPHOST
2014-12-11 10:42:29 4-Debug 1 hostname.log.Waiting for an echo of user $USER $PASS command
2014-12-11 10:42:29 4-Debug 1 hostname.log.Waiting for a response to: user $USER $PASS
2014-12-11 10:42:59 2-Warning 1 hostname.log.Did not receive expected response to command: user $USER $PASS
2014-12-11 10:42:59 4-Debug 1 hostname.log.Waiting for an echo of bin command
2014-12-11 10:42:59 4-Debug 1 hostname.log.Waiting for a response to: bin
2014-12-11 10:43:29 2-Warning 1 hostname.log.Did not receive expected response to command: bin
2014-12-11 10:43:29 4-Debug 1 hostname.log.Waiting for an echo of mkdir $FPATH command
2014-12-11 10:43:29 4-Debug 1 hostname.log.Waiting for a response to: mkdir $FPATH
2014-12-11 10:43:59 2-Warning 1 hostname.log.Did not receive expected response to command: mkdir $FPATH
2014-12-11 10:43:59 4-Debug 1 hostname.log.Waiting for an echo of put /config/$HOST.conf /$FPATH/$HOST.txt command
2014-12-11 10:43:59 4-Debug 1 hostname.log.Waiting for a response to: put /config/$HOST.conf /$FPATH/$HOST.txt
2014-12-11 10:44:29 2-Warning 1 hostname.log.Did not receive expected response to command: put /config/$HOST.conf /$FPATH/$HOST.txt
2014-12-11 10:44:29 4-Debug 1 hostname.log.Waiting for an echo of close  command
2014-12-11 10:44:29 4-Debug 1 hostname.log.Waiting for a response to: close
2014-12-11 10:45:00 2-Warning 1 hostname.log.Did not receive expected response to command: close
2014-12-11 10:45:00 4-Debug 1 hostname.log.Waiting for an echo of bye command
2014-12-11 10:45:00 4-Debug 1 hostname.log.Waiting for a response to: bye
2014-12-11 10:45:30 2-Warning 1 hostname.log.Did not receive expected response to command: bye
2014-12-11 10:45:30 4-Debug 1 hostname.log.Waiting for an echo of EOF command
2014-12-11 10:45:30 4-Debug 1 hostname.log.Waiting for a response to: EOF
2014-12-11 10:46:00 2-Warning 1 hostname.log.Did not receive expected response to command: EOF
2014-12-11 10:46:00 3-Info 1 hostname.log.Command results: 4 of 24, 20
2014-12-11 10:46:00 4-Debug 1 hostname.log.Disconnecting from hostname.loc
2014-12-11 10:46:00 4-Debug 1 hostname.log.Disconnected from 10.0.0.1
2014-12-11 10:46:00 3-Info 0 Kiwi CatTools Service All threads have finished. Now processing results...
2014-12-11 10:46:00 4-Debug 0 Kiwi CatTools Service Writing sortable HTML report to: C:\Program Files\CatTools3\Reports\Device.CLI.Send commands.htm
2014-12-11 10:46:00 3-Info 0 Kiwi CatTools Service Run Now activity has completed
2014-12-11 11:14:22 3-Info 0 Kiwi CatTools Manager Program shutdown (Manager Mode)
2014-12-11 11:14:22 3-Info 0 Kiwi CatTools Service Starting scheduler
2014-12-11 11:14:22 4-Debug 0 Kiwi CatTools Service Loading activity schedule times from database.
2014-12-11 11:14:22 3-Info 0 Kiwi CatTools Service Scheduling timer activated
2014-12-11 12:53:09 3-Info 0 Kiwi CatTools Manager Program start-up
2014-12-11 12:53:09 3-Info 0 Kiwi CatTools Manager Running in Manager Mode
2014-12-11 12:53:09 3-Info 0 Kiwi CatTools Manager Version: 3.4.0
2014-12-11 12:53:09 4-Debug 0 Kiwi CatTools Manager Attempting open of database: C:\Program Files\CatTools3\KiwiDB-CatTools.kdb
2014-12-11 12:53:09 3-Info 0 Kiwi CatTools Manager Database Connected OK
2014-12-11 12:53:10 3-Info 0 Kiwi CatTools Manager Protocol Engine 2.6.8.84 enabled
2014-12-11 12:53:10 3-Info 0 Kiwi CatTools Manager Mail Server installed
2014-12-11 12:53:10 3-Info 0 Kiwi CatTools Manager Start-up completed
SSH log
F5@hostname.loc:Active:In Sync] config # FTPHOST=IPADDRESS
[F5@hostname.loc:Active:In Sync] config # HOST=$HOSTNAME
[F5@hostname.loc:Active:In Sync] config # USER=F5
[F5@hostname.loc:Active:In Sync] config # PASS=PASS
[F5@hostname.loc:Active:In Sync] config # UPATH1=Config'/'Current'/'
[F5@hostname.loc:Active:In Sync] config # UPATH=`date +%Y'/'%m'/'%d`
[F5@hostname.loc:Active:In Sync] config # FPATH=$UPATH1$UPATH
[F5@hostname.loc:Active:In Sync] config # echo $FPATH
Config/Current/2014/12/11
[F5@hostname.loc:Active:In Sync] config # cd /config
[F5@hostname.loc:Active:In Sync] config # tmsh -c "save sys config base"
ftp -inv << EOF
open $FTPHOST
user $USER $PASS
bin
put /config/$HOST.conf $FPATH/$HOST.conf.txt
close
bye
EOFSaving running configuration...
  /config/bigip_base.conf
  /config/bigip_user.conf
  /config/partitions/DV-CUST/bigip_base.conf
[F5@hostname.loc:Active:In Sync] config # cp bigip_base.conf $HOST.conf
[F5@hostname.loc:Active:In Sync] config # ftp -inv << EOF
> open $FTPHOST
> user $USER $PASS
> bin
> close
> bye
> EOF
Connected to IPADDRESS (IPADDRESS).
220-FileZilla Server version 0.9.44 beta
220-written by Tim Kosse (tim.kosse@filezilla-project.org)
220 Please visit http://sourceforge.net/projects/filezilla/
Remote system type is UNIX.
331 Password required for f5
230 Logged on
200 Type set to I
local: /config/hostname.loc.conf remote: Config/Current/2014/12/11/hostname.loc.conf.txt
227 Entering Passive Mode (IPADDRESS,248,33)
150 Opening data channel for file upload to server of "/Config/Current/2014/12/11/hostname.loc.conf.txt"
226 Successfully transferred "/Config/Current/2014/12/11/hostname.loc.conf.txt"
14700 bytes sent in 9.2e-05 secs (1.6e+05 Kbytes/sec)
221 Goodbye
0 Kudos
Oh shoot...
The previous post was in pending.. i thought i lost it.. hence the double post.. I appologize.
Gr
thijn
0 Kudos
Ofcourse, logfiles.. i'm sorry. i should've added these in the initial post, .
Well i have two pieces of logs, one is the Kiwicattools info log, the other is session output via a SSH session on the box itself.
I do appologize.. when i post the logs this forum pushed it into a table layout.. and i dont know how to disable auto table.
Naturaly i sanitized some of the values.
Info.log.txt
2014-12-11 10:35:52 4-Debug 0   Kiwi CatTools Service   Marshaller - Running script. Device: hostname.loc
2014-12-11 10:35:53 4-Debug 1   hostname.locSSH Fingerprint: 8b:7c:0a:21:9d:3d:6d:6b:5f:db:6a:1c:10:a8:88:8d
2014-12-11 10:35:53 4-Debug 1   hostname.locConnected to 10.0.0.1
2014-12-11 10:35:53 4-Debug 1   hostname.locLogin F5 Big IP: hostname.loc
2014-12-11 10:35:53 4-Debug 1   hostname.locWaiting for command prompt
2014-12-11 10:35:53 4-Debug 1   hostname.locDeviceHostnameID: [username@hostname:Standby:In Sync] ~
2014-12-11 10:35:53 4-Debug 1   hostname.locLogin to hostname.loc was successful
2014-12-11 10:35:54 4-Debug 1   hostname.locWaiting for an echo of #!/bin/bash command
2014-12-11 10:35:54 4-Debug 1   hostname.locWaiting for a response to: #!/bin/bash
2014-12-11 10:35:54 4-Debug 1   hostname.locWaiting for an echo of FTPHOST=IPADDRESS command
2014-12-11 10:35:54 4-Debug 1   hostname.locWaiting for a response to: FTPHOST=IPADDRESS
2014-12-11 10:35:54 4-Debug 1   hostname.locWaiting for an echo of HOST=$HOSTNAME command
2014-12-11 10:35:54 4-Debug 1   hostname.locWaiting for a response to: HOST=$HOSTNAME
2014-12-11 10:35:54 4-Debug 1   hostname.locWaiting for an echo of USER=F5 command
2014-12-11 10:35:55 4-Debug 1   hostname.locWaiting for a response to: USER=F5
2014-12-11 10:36:25 2-Warning   1   hostname.locDid not receive expected response to command: USER=F5
2014-12-11 10:36:25 4-Debug 1   hostname.locWaiting for an echo of PASS=PASS command
2014-12-11 10:36:25 4-Debug 1   hostname.locWaiting for a response to: PASS=PASS
2014-12-11 10:36:55 2-Warning   1   hostname.locDid not receive expected response to command: PASS=PASS
2014-12-11 10:36:55 4-Debug 1   hostname.locWaiting for an echo of UPATH1=Config'/'Current'/' command
2014-12-11 10:36:55 4-Debug 1   hostname.locWaiting for a response to: UPATH1=Config'/'Current'/'
2014-12-11 10:37:25 2-Warning   1   hostname.locDid not receive expected response to command: UPATH1=Config'/'Current'/'
2014-12-11 10:37:25 4-Debug 1   hostname.locWaiting for an echo of UPATH=`date +%Y'/'%m'/'%d` command
2014-12-11 10:37:25 4-Debug 1   hostname.locWaiting for a response to: UPATH=`date +%Y'/'%m'/'%d`
2014-12-11 10:37:55 2-Warning   1   hostname.locDid not receive expected response to command: UPATH=`date +%Y'/'%m'/'%d`
2014-12-11 10:37:55 4-Debug 1   hostname.locWaiting for an echo of FPATH="$UPATH1$UPATH" command
2014-12-11 10:37:55 4-Debug 1   hostname.locWaiting for a response to: FPATH="$UPATH1$UPATH"
2014-12-11 10:38:26 2-Warning   1   hostname.locDid not receive expected response to command: FPATH="$UPATH1$UPATH"
2014-12-11 10:38:26 4-Debug 1   hostname.locWaiting for an echo of echo $FPATH command
2014-12-11 10:38:26 4-Debug 1   hostname.locWaiting for a response to: echo $FPATH
SSH.log
iF5@hostname.loc:Active:In Sync] config # FTPHOST=IPADDRESS
ftp -inv << EOF
open $FTPHOST
user $USER $PASS
bin
close
bye
> open $FTPHOST
> user $USER $PASS
> bin
> close
> bye
> EOF
230 Logged on
200 Type set to I
221 Goodbye
0 Kudos
