cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Wireless LAN Controller config backup
Using 3.11.2 but having trouble backing up the config for Cisco WLC 5800. 1-error : TFTP Backup failed: error with commands or TFTP file not found. Using the Device.Backup.TFTP activity. Device variation with additional command: Showing Running Config is checked and I entered show run. AAA username/password and SSH username/password are filled in along with the initial login requires username/password being checked. Not sure if anyone else has had issues, or perhaps I am missing a critical setting?
Labels (2)
Tags (1)
