cancel
Showing results for
Search instead for
Did you mean:
Create Post
Strange output in Mikrotik Backup
Hi All,
We've purchased KiwiCattools to perform regular backups of our Mikrotik Routers.
Logging in and exporting goes without a problem however if we look at the exported files then there's some strange output.
The config file starts with the text below.
[admin@XXXX] >
[admin@XXXX] >
[admin@XXXX] > export verbose
# dec/28/2017 16:11:14 by RouterOS 6.27
# software id = TI2W-S6JC
Is it possilble to remove this text so that the first line in the config starts after the third "#"
Thanks in advanced.
Labels (2)
Tags (1)
0 Kudos
1 Reply
Level 9
Why do you need to remove it?
If it's for Compare reports then use ignore text See >>> SolarWinds CatTools
Rob
0 Kudos
