Running the 30 day trial of Cattools 3.4.0 as we are evaluating 3rd party tools for backing up CUE.
Following the directions, I created a device for the 2800 ISR router that contains the AIM module. This device is set up as a Direct Connect using telnet (23). Our routers use tacacs AAA authentication, so in the password sections I have my AAA username and password. I have initial login requires a username/password checked as well as enable mode uses AAA username/password. I am able to successfully run the Device.ConnectivityTest.Login to this device.
I then created a device for the unity module.
Device type: Cisco.Other.CUE
Host address: service-module service-Engine0/0 session
Model: AIM-CUE
Connext via: Cisco Router 1 <----- this is the router device I created above.
Method: Session
Unity is also setup for AAA authenication and the device is configured that same as the router in regards to the AAA username and password.
Runing the Device.ConnectivityTest.Login to the CUE fails every time.
2009-06-25 13:44:46 3-Info 0 Kiwi CatTools Performing activity - Run Now
2009-06-25 13:44:46 3-Info 0 Kiwi CatTools Loading activity: Device.ConnectivityTest.Login. Schd: 1
2009-06-25 13:44:47 4-Debug 0 Kiwi CatTools Marshaller - Running script. Device: Cisco CUE 1
2009-06-25 13:44:47 4-Debug 1 Cisco CUE 1 ConnectViaGet - Device: Cisco CUE 1 says to connect via device: Cisco Router 1
2009-06-25 13:44:47 4-Debug 1 Cisco CUE 1 ConnectViaDo - getting all fields Cisco Router 1
2009-06-25 13:44:47 4-Debug 1 Cisco CUE 1 ConnectViaDo - Connecting directly to: Cisco Router 1
2009-06-25 13:44:47 4-Debug 1 Cisco CUE 1 Connected to 10.80.20.6
2009-06-25 13:44:47 4-Debug 1 Cisco CUE 1 Login CiscoRouter: Cisco Router 1
2009-06-25 13:44:50 4-Debug 1 Cisco CUE 1 Login to Cisco Router 1 was successful
2009-06-25 13:44:50 4-Debug 1 Cisco CUE 1 DeviceHostnameID: r-uspie101cme
2009-06-25 13:44:50 4-Debug 1 Cisco CUE 1 ConnectViaDo - Connecting to: Cisco CUE 1
2009-06-25 13:44:50 4-Debug 1 Cisco CUE 1 Issuing commands to connect from Cisco Router 1 to Cisco CUE 1 via Session
2009-06-25 13:44:50 1-Error 1 Cisco CUE 1 Failed to connect to session with command (service-module service-Engine0/0 session)
2009-06-25 13:44:50 4-Debug 1 Cisco CUE 1 ConnectVia failed - Cisco CUE 1
2009-06-25 13:44:50 3-Info 1 Cisco CUE 1 Login results = VTY: Failed, Enable: N/A, HostID: N/A
2009-06-25 13:44:50 4-Debug 1 Cisco CUE 1 Disconnected from service-module service-Engine0/0 session
2009-06-25 13:44:50 3-Info 0 Kiwi CatTools Stopping Activity.
2009-06-25 13:44:50 3-Info 0 Kiwi CatTools All threads have finished. Now processing results...
2009-06-25 13:44:50 4-Debug 0 Kiwi CatTools Writing sortable HTML report to: C:\Program Files\CatTools3\Reports\Device.ConnectivityTest.Login.htm
2009-06-25 13:44:50 3-Info 0 Kiwi CatTools Run Now activity has completed
