cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Issue with Cattools
I recently upgraded from Cisco 3560X switches to 9300 switches. When I create the profile for the devices in cattools, I can ping and I can ssh from the profile and cattools runs on the machine I've tested it from, but when I run the job, I get errors stating that cattools cannot reach the device.
"Failed to connect to device; No response from remote host". I don't get it. I can still backup all my other switches with no issue, I also just installed 2 Nexus 7710s and Cattools backed up all 8 VDCs I have configured.
Any suggestions?
0 Kudos
1 Reply
Level 15
You can enable debugging, File\Enable capture mode, and this will show you verbose communication, and the device may need to be edited.
0 Kudos
