cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
How to restore config on Avaya Switches ?
I'm currently testing to restore the config that I saved using Kiwi Cat Tools. I add a task "Device.TFTP.Upload.Config" to restore the configuration but I'm getting the message "Device type : Nortel.Switch.Ethernet has not yet had this functionnality added". Then how can I restore the configuration if the functionnality is not added for those switches.
Thank you very much.
Regards
Labels (2)
0 Kudos
