cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Custom Script for JUNOS help
I've created a custom device to support my Juniper SRX gateways because the Juniper.Router's CLI.SendCommands seemed to fail (configure gives command error) and the
CLI.ModifyConfig said it wasn't yet supported.   The problem I have is when I send it commands, times out waiting for an echo of the commands.  The commands take (configuration modifications) but the script takes way too long and ends with a failure.   How can I disable the waiting for an echo?
JP
Labels (1)
0 Kudos
1 Reply
Level 14
Hi JP,
Meta command may be what you need to send along with your CLI command.  Take a look at the online Help file here:
http://www.kiwisyslog.com/help/cattools/act_metactumcommand.htm
Probably want to experiment with the %ctUM: EchoOff and the %ctUM:Timeout xx meta commands.
Steve
0 Kudos
