Hello,
I am currently evaluating Cattools for a client and have been happily using it on Cisco and Juniper devices without issue.
I am able to log onto all of the extreme switches and issue scripted commands with no issues, but when trying to save the configuration to NVRAM the "save" command times as as not receiving the expected response to the command. It makes no difference whether I select to say yes to prompts or not.
The script being applied is -
configure syslog add <IPv4 address>:5000 vr VR-Default local0
enable log target syslog <IPv4 address>:5000 vr VR-Default local0
configure log target syslog <IPv4 address>:5000 vr VR-Default local0 filter DefaultFilter severity Debug-Data
configure log target syslog <IPv4 address>:5000 vr VR-Default local0 match Any
configure log target syslog <IPv4 address>:5000 vr VR-Default local0 format timestamp seconds date Mmm-dd event-name none priority
save <--- fails here!
Devices are defined as Extreme.switch.general and amending the device model make no difference. Commands are being issued using the device.cli.send activity.
Any ideas?
Keith
