cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Backup Extreme Summit switches using TFTP commands
Jump to solution
Hi, We have just installed some extreme switches and currently
it is backing up using model X450-24X running the show configuration command.
We are wanting to run the following below command and wondered whether this
would be possible if we had a variations file and running a TFTP server on
server where cat tools is installed.
tftp put x.x.x.x vr "VR-Default"primary.cfg **Saved file name***.cfg
The above command makes it easier to restore configs if we were to have issues.
We tried running Device.Backup.TFTP activity but it currently only supports Cisco Devices.
Labels (2)
0 Kudos
1 Solution
Level 15
Have you tried using a Send.CLI.Commands activity?  Please see this link:
SolarWinds CatTools
0 Kudos
Level 15
SolarWinds CatTools
0 Kudos
thanks all working now with your suggestion.
0 Kudos
