cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
SSL Certificate generation
When DPA and Oraion install, they create SSL certificates with the CNAME as the local hostname. Unfortunately as we use a managed service the domain of the host does not exist in our network. Consequently I can't add it to the DNS so I have to use the IP address to connect. This of course give a certificate error as the hostname does not match.
The quesiton is, can I regenerate the certificate with a CNAME of my choice that I can use on my internal network?
Tags (1)
0 Kudos
