cancel
Showing results for
Search instead for
Did you mean:
Create Post
Info about switch configuration, script?
Hello there,
I need to know which of the switches under SolarWinds monitoring have enabled login via Radius and Tacacs server.
I was thinking of creating a script that could simplify my work, as I really do a lot of them.
Can you help me take the first steps?
On which card can I schedule an activity like this?
0 Kudos
1 Reply
Do you have NCM? If so, you can use NCM to write a script to give you the info you seek. You could do it as a Job or a Compliance task.
0 Kudos
