cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Orion SDK Python Script
Hello All,
I need to write a Python script to make IPAM subnet reservation easier. I am planning to make use of the orionsdk Python package for this purpose. But I am facing a couple of issue with this:
- I am not able to find a proper document to refer for Python implementation.
- Is there is any sample script that I can refer to?
Requirement:  I have a bigger /23 subnet in in IPAM and I need to allocate /24 from that /23 subnet. So finding the next available /24 and reserving it are the steps involved.
0 Kudos
1 Reply
Hello,
All the Python samples and documentation is up on GitHub. Is this what you’re looking for?
https://github.com/solarwinds/orionsdk-python
Good luck -
0 Kudos
