cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
[ IPAM ] Inquire about Neighbor Scanning when using polling engine
Hello
Due to security regulations, IPAM is intended to be used by using a polling engine.
In this case, when using Neighbor Scanning, does the polling engine perform SNMP communication with neighboring devices?
Or does the main engine communicate with adjacent equipment?
0 Kudos
1 Reply
You can set which engine will poll for each subnet scan. I believe that one will always be used.
0 Kudos
