cancel
Showing results for
Search instead for
Did you mean:
Create Post
Editing multiple scopes does not work.
Jump to solution
If I try and edit multiple scopes, it goes through the motions but when I check my scopes, none have been updated. All I'm doing is selecting multiple scopes.
Click on the edit button
Update some of the fields (note it's picked up I'm editing 4 subnets)
click on Save
Then I go back to my scopes and none have changed.
Anyone else have the same issue? I'm using NPM 12.5 & IPAM 4.9.0
0 Kudos
1 Solution
Level 12
Kindly upgrade to 2019.2 HF3 with IPAM 4.9 HF1.
Success Center
Level 12
Success Center
I've upgraded to HF3 and it now works again. Thanks!
I can confirm this happens to me as well.
Orion Platform 2019.2 HF1, SRM 6.9.0, IPAM 4.9.0, SAM 6.9.1, SCM 1.2.0 HF1, DPAIM 11.2.0, NCM 8.0, VMAN 8.5.0 HF1, Toolset 11.0.8, PM 2.1.7, NetPath 1.1.5, NPM 12.5, NTA 4.6.0
If you open a ticket, let me know with a direct message, and I will also open one.
Thanks mate. I will log a ticket when I can - I just need to be given access on the account here.
