cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
SNMPSET via Button Click on an Orion View
hi All,
Long time reader, 1st post here. I manage a solarwinds NPM instance for a large private telecom network. Im trying to figure out how I can best put a function into NPM that allows me to execute an SNMP_SET Command on a node via a button press within an NPM View? I could settle with executing an application on the Solarwinds Box (snmpset CLI tool for example), which I know NPM can do, however what would be a easy way to manually trigger the action via an object click on a view?
0 Kudos
