cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
SNMP
good day to all .
i am a newbie in solarwind management tools. i'd like to view the CPU gauge but i am getting an error "192.168.1.1 is not responding
to SNMP queries" .
the server that i am querying is a linux server RHEL4 2.6 . i checked the snmp daemon and it was running.
can you please help me.
thank you very much.
ivandg
0 Kudos
1 Reply
Level 8
Have you setup a 'community string' for your monitored device??!... sometimes they are set out of the box to 'Public' or 'public' (they are case sensitive!!)....
You will need to then add this string into the community id for the device then using the SMNP monitoring tool
Martin J. Hamilton... lost in a sea of snmp...
0 Kudos
