cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
SNMP Return Address Issue
Jump to solution
Hi All,
Here's an weird problem. I have a bunch of Switches that I need to monitor. When I try to import them in, inspite of they being SNMP enabled, I can only see them as ICMP devices. Reasons for that is as follows:
  1. These are Hirschmann Switches and NOT Cisco switches
  2. They do not use the same interface to send back SNMP query responses.
  3. They use the next available interface to send the SNMP query response
  4. SolarWinds is not being able to process the incoming requests and hence allocating ICMP as the device level
Is there any way I can get SolarWinds to receive the responses and be able to process them, so that my Hirschmann switches are registered as SNMP devices and not ICMP
Looking forward to any response
Regards
Labels (1)
0 Kudos
1 Solution
Level 14
I have been going through the Hirschmann documentation that I could find and I am not seeing documentation or information pertaining to SNMP Responses separate interface from the response. Are you seeing this on a Packet Capture?
If the IP of the interface is different, then none of our software will see it as it will be considered a different device.
0 Kudos
1 Reply
Level 14
0 Kudos
