cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Question about finding SNMP OIDs for MPLS
Hi there,
I'm implementing an SNMP solution and I'm at the point where I need to get MPLS information with SNMP.
Specifically, I need to get the MPLS labels. I've been digging through MIBs and OIDs and I'm able to gather all the data equivalent to "show mpls forwarding-table" (cisco IOS router).
The problem is, that this table doesn't show the MPLS labels associate with BGP learned routes, those labes are found with the "show ip bgp vpnv4 all labels" command.
I've searched the MplsLsrMib, MplsLdpMib, the VPN mibs and the BGP4 mib and so far I haven't been able to find these VPNv4 labels anywhere. I'm starting to think that this information just isn't available through SNMP!
If anyone could help or point me in the right direction it would be a tremendous help.
Thanks!
Ron.
Tags (3)
0 Kudos
