cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
Mapping Question
Hello Thwackers,
When we go to a node and to the Map tab, we find that physical interfaces will show the node on the other side of the interface, while tunnel interfaces show only the interface itself and not the node on the other side. These are GRE tunnels, and we have modified the topology configuration file to include interface type 131. Also note that we are on NPM 12.3, which might be relevant as I know mapping has been enhanced in NPM 12.5. Questions:
1. Is this be design, meaning we can't have a map that shows both side of a tunnel interface?
2. Has this changes with NPM 12.5?
Thanks Everybody, Brent
Node
Interface
Labels (1)
0 Kudos
