cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
HP 5900 VLANS NAMES NOT DISPLAYING IN SOLARWINDS
We have SW 2019.4 and when you look at the list of VLANS from NPM you see some with names and most with out a name.
When I expand a specific VLAN say 6 I see:
VLAN ID:               NAME                    NODE NAME
VLAN 6:
                              HHSDC               SCAC-HP3800
                              VLAN 0006          HP5900
                              HHSDC               SCAC-3
                              HHSDC               2920-Works
As you can see in the list above for the HP5900 it displays the VLAN name as VLAN 0006 not HHSDC.
In the 5900 running config the VLAN 6 is displayed as:
vlan 6
name HHSDC
description HHSDC
Why is this and can it be resolved with a Device Template?
I noticed that the current device template is a custom one made by someone not SolarWinds..
<Configuration-Management Device="" SystemOID="1.3.6.1.4.1.25506.11.1.78">
  <Commands>
    <Command Name="RESET" Value="screen-length disable${CRLF}" />
    <Command Name="Reboot" Value="reboot${CRLF}y${CRLF}y" />
    <Command Name="EnterConfigMode" Value="system" />
    <Command Name="ExitConfigMode" Value="quit" />
    <Command Name="Startup" Value="saved" />
    <Command Name="Running" Value="current" />
    <Command Name="DownloadConfig" Value="display ${ConfigType}" />
    <Command Name="UploadConfig" Value="${system}${CRLF}${ConfigText}${CRLF}${quit}" />
    <Command Name="DownloadConfigIndirect" Value="copy ${ConfigType} ${TransferProtocol}://${StorageAddress}/${StorageFilename}${CRLF}${CRLF}${CRLF}" />
    <Command Name="UploadConfigIndirect" Value="copy ${TransferProtocol}://${StorageAddress}/${StorageFilename}  ${ConfigType}${CRLF}${CRLF}" />
    <Command Name="DownloadConfigIndirectSCP" Value="copy ${ConfigType} ${TransferProtocol}://${SCPServerUserName}@${SCPStorageAddress}/${StorageFilename}${CRLF}${CRLF}${CRLF}${CRLF}${SCPServerPassword}" />
    <Command Name="UploadConfigIndirectSCP" Value="copy ${TransferProtocol}://${SCPServerUserName}@${SCPStorageAddress}/${StorageFilename}  ${ConfigType}${CRLF}${CRLF}${SCPServerPassword}" />
    <Command Name="EraseConfig" Value="write erase${CRLF}Y" />
    <Command Name="SaveConfig" Value="save" />
    <Command Name="Version" Value="display version" />
    <Command Name="Disconnect" Value="quit" />
  </Commands>
</Configuration-Management>
Any thoughts on how to correct this?
0 Kudos
