cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Discrepancy
Has anyone come across this or can explain it:
I'm looking at availibilty of a server over the last month and it tells me its 99.99166% but when I goto reporting and check the availibility report I see a slightly different number, I see 99.904. This could be attributed to rounding errors when calculating averages but which one would be more accurate?
Thanks.
0 Kudos
1 Reply
Level 15
The web report is more accurate.
I've posted the explanation in the Orion forum, and Solarwinds does have a fix for the Report Writer for this.
-=Cheers=-
NG
0 Kudos
