cancel
Showing results for
Search instead for
Did you mean:
Create Post
ASR 1001 - X
I have added a manual poller via Thwack Community to poll my ASR 1001-X and it is not supported. I also go to the PollerCheckerTool and find no details for my device.
Do i need an updated Solarwinds deployment, or how can I add support for this device?
Tags (3)
0 Kudos
1 Reply
What version of NPM?
I'm not sure what you mean by manual poller but have you added this device into NPM via SNMP? I think that should show you all you most likely need.
0 Kudos
