cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
Not set up to channel Verizon card? Dial Verizon phone number.
One of the pullings in features of the application is that it grants you to have a
card. The card works sufficiently like a check card. In any case, to start the card
you need to look at it. If you can't get a Verizon card, by then check the camera.
In case see on an impression, by then dial the Verizon phone number for
additional assistance to fix the issue.
Labels (1)
Tags (1)
0 Kudos
