cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Monitor Hard Drive Failure/ RAID on DELL PowerEdge Sever
I would like to monitor Physical Disk failure of Dell PowerEdge server through IDRAC functionality, is it possible using SolarWinds.
0 Kudos
1 Reply
Level 9
I guess you already tried just adding a new node with entering the iDRAC IP address by using SNMP.
When I do it like this, Orion does not show any Disks in the discovered ressources:
But you can add the Node like this and than add a New Universal Device Poller using the DELL OID for physikal disks state
(1.3.6.1.4.1.674.10892.5.5.1.20.130.4.1.4)
Manual: https://www.dell.com/support/manuals/us/en/04/idrac7-8-lifecycle-controller-v2.40.40.40/snmp%20idrac...
