cancel
Showing results for
Search instead for
Did you mean:
mharvey
Level 17
Custom SWQL Query Resource Help
Jump to solution
I'm working with EOC trying to use the Custom SWQL query resources to get a resource to show me all Acknowledged alerts from Orion servers.  The following works in SQL:
Select
EOC_AlertStatus.ObjectName, EOC_AlertStatus.TriggerTimeStamp,
EOC_AlertDefinition.Name, EOC_AlertStatus.Acknowledged,
EOC_AlertStatus.AcknowledgedTime, EOC_AlertStatus.AcknowledgedBy
From EOC_AlertStatus
Join EOC_AlertDefinition on EOC_AlertStatus.AlertDefID = EOC_AlertDefinition.AlertDefID
Where EOC_AlertStatus.Acknowledged = 1
But if I try to use it following the SWQL documentation I've found, trying to run it this way:
SELECT
EOC.AlertStatus.ObjectName, EOC.AlertStatus.TriggerTimeStamp,
EOC.AlertDefinition.Name, EOC.AlertStatus.Acknowledged,
EOC.AlertStatus.AcknowledgedTime, EOC.AlertStatus.AcknowledgedBy
FROM EOC.AlertStatus
INNER JOIN EOC.AlertDefinition on EOC.AlertStatus.AlertDefID = EOC.AlertDefinition.AlertDefID
WHERE EOC.AlertStatus.Acknowledged = 1
results in the resource being unable to process the request.  Anyone thoughts?
Tags (3)
mharvey
Level 17
Re: Custom SWQL Query Resource Help
Jump to solution
Figured out the SWQL that I needed to use.  For anyone else who runs across this, here is what you'll need.
SELECT q.ObjectName, q.TriggerTimeStamp, q.Name, q.AcknowledgedBy, q.AcknowledgedTime, q.Notes, q._LinkFor_ObjectName, q._IconFor_ObjectName AS [_IconFor_ObjectName], q._LinkFor_Name
FROM
SELECT a.ObjectName, a.TriggerTimeStamp, d.Name, a.AcknowledgedBy, a.AcknowledgedTime, a.Notes, o.Website + '/Orion/View.aspx?NetObject=N%3A' + ToString(n.NodeID) AS [_LinkFor_ObjectName], '/images/Small-' + GroupStatus AS [_IconFor_ObjectName],'/Default.aspx?viewId=1004' AS [_LinkFor_Name]
FROM EOC.AlertStatus a
JOIN EOC.AlertDefinition d ON a.AlertDefID = d.AlertDefID
JOIN EOC.Node n ON n.NodeID = a.ActiveObject AND a.ObjectType = 'Node' and n.OrionID = a.OrionID
JOIN EOC.Orion o ON o.OrionID = a.OrionID
where (Acknowledged = '1')
UNION
(SELECT a.ObjectName, a.TriggerTimeStamp, d.Name, a.AcknowledgedBy, a.AcknowledgedTime, a.Notes, o.Website + '/Orion/View.aspx?NetObject=I%3A' + ToString(i.InterfaceID) AS [_LinkFor_ObjectName], '/images/Small-' + s.StatusName + '.gif' AS [_IconFor_ObjectName],'/Default.aspx?viewId=1004' AS [_LinkFor_Name]
JOIN EOC.Interface i ON i.InterfaceID = a.ActiveObject AND a.ObjectType = 'Interface' AND i.OrionID = a.OrionID
JOIN EOC.StatusInfo s ON s.StatusId = i.Status
where (a.Acknowledged = '1'))
UNION
(SELECT a.ObjectName, a.TriggerTimeStamp, d.Name, a.AcknowledgedBy, a.AcknowledgedTime, a.Notes, o.Website + '/Orion/View.aspx?NetObject=AM%3A' + ToString(c.ComponentID) AS [_LinkFor_ObjectName], '/images/Small-' + c.Application.Node.GroupStatus AS [_IconFor_ObjectName],'/Default.aspx?viewId=1004' AS [_LinkFor_Name]
JOIN EOC.APM.Component c ON c.ComponentID = a.ActiveObject AND a.ObjectType = 'APM: Component' and c.OrionID = a.OrionID
) q
ORDER BY q.TriggerTimeStamp DESC
rsprim
Level 12
Jump to solution
Matt,
How were you able to test this with the SDK?  I'm unable to connect to the EOC server with v1.9 of the SDK installed on my EOC v1.5 server.  I keep getting unable to connect to Information Service.  The server has rejected the client credentials.
Robert
0 Kudos
mharvey
Level 17
Jump to solution
This was not done with the sdk, this was done in a custom query resource on the EOC page.
0 Kudos
rsprim
Level 12
Jump to solution
Thanks for the quick reply Matt.  Do you know if it's possible to use the SDK to test code like this?  If not, perhaps someone from SolarWinds can respond.  I'd like to be able to use the SDK to test it prior to placing it on a production server.
0 Kudos
mharvey
Level 17
Jump to solution
I don't think the SDK would be of use trying to connect to an EOC server. Fortunately with EOC, you can create a view that only you see, or use the customize page option and add the custom query to your view rather than the whole view for all users to see.
0 Kudos
contactjt
Level 10
Jump to solution
Just a note the SDK does connect to EOC fine and is decent for testing queries. You have to make sure the SWIS type is set for EOC in the drop down. Also the EOC website applys some filters the SDK doesn't so while good you should always verify the final result on the website for additional issues.
0 Kudos
