Hi Guys,
I just noticed the two aforementioned data formats under the Orion Report Writer.
Please what do they mean?
How do they affect generating a report via using the Orion Report Writer tool?
Regards,
Hi Guys,
Regards,
A raw value is the value straight from the database, and the cooked value is the one that you would see in the web portal.
One example is node status. A raw value would be "1" where as the cooked value would be "up".
In general, you would want to be using cooked values.
HTH
Stuart
