cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Tripplite UPS says it's own MIB isn't compatible
Hey folks.  We recently added some Tripplite Smart1500RM2U's to our network, all have the WEBCARDLX cards installed on them.
I would like to receive notifications when the UPS' go on battery.  Tripplite has MIB 1.3.6.1.4.1.850.1.1.7.2 available for this and it is in the MIB browser.  However when I try to add it to the device it says it is unable to poll for this OID and when I do an SNMP walk on the IP that doesn't show as an available OID.
I called TrippLite and they said that it should work fine so long as I load their MIBs to my Orion environment.  I thought this was done via UdNP but I believe I'm mistaken.
Can someone point me in the direction of getting this alert to work for this UPS?
Brandon
0 Kudos
1 Reply
You are misunderstanding, that OID is a trap, not a polled OID.  If you have set up the UPS to send traps to Orion then whenever there is a status change it will fire off the message and you could potentially trigger an alert off that event, but you can't poll for it on demand.
- Marc Netterfield, Github
0 Kudos
